News Pads Squeaking Problem
Old Apr 2, 2009 | 08:52 AM
bcrichguitars's Avatar
couldnt the dirt and little pieces of graval getting caught in there cause it to squeak? How could this be getting on the backing plate of the inside pad and around the piston in the caliper?
Old May 6, 2009 | 09:44 AM
Gregg08_CES's Avatar
Default Same issue
I just recently replaced my front pads, and mine are squeeking like crazy.
I bought the lifetime warranty pads from AutoZone, ceramic.
I greased the heck out of everything and they still squeek, after reading the brake pad changing guidelines it appears they want you to grease BOTH sides of the shims. This entails removing the shim from the pad - which I did not do. I'm going to try that to see if it helps.
If it doesn't help, i think these pads are just going to squeek.
Old May 7, 2009 | 12:06 PM
jwmm04's Avatar
August 2010 ROTM
Auto Zone pads will squeak 90% of the time, no matter what you do. And to the OP: Another thing to try is some of this stuff you put on your pads, called brake-quiet or something like that. When I first got my car, it had some fairly new factory pads, which squeaked like every other time I hit the brakes. Put some of that stuff on, and never heard a squeak again for the 6 months they were on, until I changed my pads.
Old May 7, 2009 | 12:55 PM
Really? I Have Changed Brakes for myself and family bout a dozen times and not once have they squeaked...
Old May 17, 2009 | 07:08 AM
Engelhonda37's Avatar
this is happening to me as well, started after i put on new rotors though, but yes it is my passenger side as well and idk why they squeak. it doesnt happen when i brake but when my foot is off the pedal is when the squeaking begins.
Old May 17, 2009 | 06:17 PM
GReddy_Civic's Avatar
Snail'n Admin
FYI, oem honda rotors do NOT like non-honda pads. they squeek almost every time
Old May 26, 2009 | 12:31 PM
EJ8_Man's Avatar
Default Same squeek problem
Hi,
So I have this same problem with my rear driver side brake. I have an Integra rear disk conversion. I replaced the pads and rotors, and noticed that rear driver's side pad is wearing at an angle, which is the source of the squeak. It looks like the piston is pushing harder on one edge causing uneven wear. How much is involved with re-conditioning the calipers? Are there any write-ups for this?
Thanks
jhsplaya08
Oct 9, 2007 07:26 PM
Naudlee
May 26, 2006 09:44 PM
twixiemix
Sep 22, 2005 06:14 AM
mbking2004
Aug 17, 2005 04:36 PM
k2rad
Aug 15, 2005 02:30 PM
