poly r.i.p
2000 ex, I hit the curb @ 60 mph. The front right wheel is bent. cause the fender bent also!
the wheel, tires are messed up.
what 's posibly wrong the my car? suspension damages? strut? spring? camber? how much could it be to fix it?
I know that i need an alignment afterall
thanks yall!!!!
similar thing happened to me a while back...check the steering knuckle, contorl arm, boots, and wheel bearing. i had to get a new steelie aswell, i believe the total cost to get it fixed at the stealership was about $900[:@]. the spring should be ok but the strut might have some damage if the impact was reallly harsh.
hit the curb straight on, at an angle, sideswiped it?? could you drive the car home? what do you mean by "tires are messed up"?
my friend hit a curb sideways in his mazda at 20mph and it cost him somewhere around $800. good luck to you...
they told me 800-1500
strut, lower arm, FENDER (i want an aftermarket one, so hold on to that fender), boots.
the steelie messsed up. I will put the yellow rims back on! yay!!!! (I had steelies on during the crash, so lucky)
