pressure: door sticker or sidewall?
Old Nov 16, 2010 | 11:14 AM
MaximusFunk's Avatar
Default pressure: door sticker or sidewall?
My tires are the same size as stock and they recommend 44 psi, but my car recommends 30f/29r.
Which of these should I follow, or should I go in between?
Are there advantages in performance/fuel economy by going one way or the other?
Old Nov 16, 2010 | 11:47 AM
DaOne's Avatar
I think you always go by whatever the car recommends.
thats what my auto class teacher told us..
Old Nov 16, 2010 | 02:17 PM
the sticker
Old Nov 17, 2010 | 08:04 AM
civicexracer's Avatar
Door jam should be the minimum psi to run, and normally what you should run... That 44psi is probably the max on the tires, so don't go beyond that.
Old Nov 17, 2010 | 02:12 PM
jdmco's Avatar
i usually have all tires at 36 because 30 seems underflated to me
especially when i got a full car
Old Nov 18, 2010 | 09:12 PM
Scott53092's Avatar
I don't go off the sticker unless they are same brand and model as the oem tires. I always look at the max on the tire and go from there. In my car I run 34 psi right now, do about 30 in summer.
At Acura we do 36 on suvs for winter, 34 for cars in winter. 34 for suvs in isummer, 32 for cars in summer. So around there is a good estimate.
Old Nov 19, 2010 | 10:31 AM
rc2904's Avatar
I do 40 because it makes not having power steering a little less noticeable.
Old Nov 19, 2010 | 05:20 PM
Scott53092's Avatar
^^ eeek that's really high
Old Nov 19, 2010 | 09:24 PM
MBrent's Avatar
July 2010 ROTM
34psi yr round for me.
Old Nov 19, 2010 | 09:47 PM
35 psi here, door sticker says 32
