rear brakes
Old Apr 29, 2005 | 08:00 AM
vmf's Avatar
vmf
Default rear brakes
hey guys, my 2001 civic has drums for rear brakes, are there any kits on the market to put the disk brakes? o would also like to change the front ones as well.
what would you recommend?
Old Apr 29, 2005 | 11:12 AM
frewcivic's Avatar
Default RE: rear brakes
what ever you do be careful about swaping drums to disc breaks. There is a valve in the hydro system that could make a rear disc lock up. So if you get discs for your rear make sure you change the right valve! its either the main meatering valve or the proportioning vavle.
Old Apr 29, 2005 | 11:15 AM
polo708's Avatar
most setups, swapping the rear drums to brakes will cause some problems... the rear will lock up quicker than the front discs and thats bad. Id recommend a big brake kit for the front to equalize the added stoppage in the rear.
Old Apr 29, 2005 | 03:43 PM
vmf's Avatar
vmf
any particular kits for the front and rear?
Old Apr 29, 2005 | 04:35 PM
D16z6's Avatar
AEM makes rear disc brake conversion for civic but it cost $900.
Old Apr 29, 2005 | 04:41 PM
StifflersMom's Avatar
Cat Fuсker
Proportioning valve has to be changed...dunno about your year though
Old Apr 29, 2005 | 07:42 PM
vmf's Avatar
vmf
where can i find out if it can be done on my car?
Old Apr 30, 2005 | 03:43 AM
Pete's Avatar
go to a junkyard and get the stuff from a TEG with rear discs.
Old May 14, 2005 | 12:16 AM
sacicons's Avatar
yeah, i know its kinda old, but i just saw this. no, they wont lock up. the 5th gens have smaller front brakes, and rear discs on some EXs and SIs, and they dont have problems. upgrading the fronts is a great idea, but not absolutely necessary. the proportioning valve also isnt necessary, but it actually sends MORE power to the rear, since they can handle more braking responsibility with disks than drums. ive had the rears on for a long time, with the stock prop valve, with no problems.
jonsaidthat
May 30, 2010 09:30 PM
ahhsimon
Jun 14, 2006 09:52 AM
LayinLo
EP Swaps
Oct 31, 2005 06:40 PM
faceless_civic
Nov 17, 2004 10:19 PM
NTX
May 7, 2004 11:25 PM
