Replacing Tokico Illuminas?
Old Apr 18, 2007 | 10:57 AM
xkeseriesi's Avatar
Default Replacing Tokico Illuminas?
I have some Tokico Illuminas lowered on H&R sport springs on an '00 ex coupe, and it seems like one or both of the front struts have gone bad. Seeing as how the warranty for the struts is voided since my car is lowered more than an inch, should I bother to replace the front one or two struts, or should I just go with a set of four struts of another brand? It seems like Illuminas weren't designed to be used on a car lowered that much. Also, I've heard this is a common problem with Illuminas.
Old Apr 18, 2007 | 11:19 AM
xkeseriesi's Avatar
Default RE: Replacing Tokico Illuminas?
After doing some searching, do you think Tokico HP's would do the trick?
Old Apr 18, 2007 | 08:30 PM
mxs's Avatar
mxs
well, they're cheaper.... so when you have to replace them again, it won't cost as much.....
the illuminas are supposed to be better than the HP's
Old Apr 18, 2007 | 11:19 PM
xkeseriesi's Avatar
I realize that the Illuminas are supposed to be better, but do you think the adjustability of it makes it more vulnerable to breakage? In any case, do you think I should replace the busted ones, or replace all four with something else?
Old Apr 18, 2007 | 11:28 PM
drbyers's Avatar
all four with something else.
Old Apr 19, 2007 | 01:37 PM
xkeseriesi's Avatar
What shocks would you recommend with my H&R sport springs?
Old Apr 19, 2007 | 04:06 PM
jonyg98civicex's Avatar
brand new tokico HP's for sale like you were asking........ https://www.hondacivicforum.com/m_338132/tm.htm
make an offer
Old Apr 20, 2007 | 07:27 AM
cncivic's Avatar
I've read a bit about it, Koni Yellow seem to be a good choice i think. I would like to have some input, i was considering getting some Tokico, but i'm expecting them to last as long as the stock ones. I think lowering 1.5-2 inches is common thing, so would the Koni Yellow be a good set of shocks ?
cncivic
Old Apr 20, 2007 | 08:20 AM
mxs's Avatar
mxs
yes, they're excellent shocks.
Nochek
Apr 8, 2007 09:47 PM
ISSABELLE19
Mar 27, 2007 12:09 AM
ISSABELLE19
Mar 16, 2007 12:52 PM
88dxcivichb
Dec 3, 2005 03:49 PM
glada96EX
Aug 11, 2005 09:52 PM
