Rim quesstion
Old Nov 30, 2008 | 08:43 AM
Cyphen's Avatar
Default Rim quesstion
i found a guy broke down on the freeway yesterday he had a toyota celica like and 88 or something he told me and the tire size on one tire on the rim was 195/60/14 on front, and the back where 185/60/14, would these rims fit on my 93 dx coupe? with no problems his rims where 4 lug. stock tire size on my car is 175/13
Old Nov 30, 2008 | 08:46 AM
xsteinbachx's Avatar
same bolt pattern?
Old Nov 30, 2008 | 09:44 AM
Assuming the correct bolt pattern, they'll fit. But why the wider tires in front? Just so you know, if the wider tires go in front, your speedo/odo will read 2% lower than stock (speedo will say you're going 58.7 when you're going 60)
Old Nov 30, 2008 | 01:11 PM
Big Panda's Avatar
Tire size (what you have listed) really has very little to do with WHEEL size or specs.
There's plenty of wheels out there( new OEM, used and of course Aftermarket)....just get something MADE for your Civic.
Old Nov 30, 2008 | 01:28 PM
Cyphen's Avatar
Yeah i dont know, they looked like the same bolt pattern not sure if they where or not only way to cehck is to take one tire off and put on mine?
Old Nov 30, 2008 | 02:08 PM
more or less. Or you could just consult google.
Old Nov 30, 2008 | 09:47 PM
search on google for 88 celica lug pattern
EDIT: I just did, and yes, the lug pattern is 4x100, just like your civic
it will fit
Old Dec 5, 2008 | 06:07 PM
KarTuneMan's Avatar
They will not fit. The Yota is a 4 on 4.5, and yer honda is 4 on 100.
Cyphen
Nov 18, 2008 07:50 PM
Cyphen
Oct 8, 2008 09:51 AM
INJENalltheway
Jan 24, 2005 04:37 PM
ibpufinstuff82
Jan 19, 2005 04:02 AM
Lowrider
Oct 29, 2004 11:45 PM
