Springs
search search search.......but a set of Tein S-Tech will run you about $160 and it’s like a 1.8 drop but they work with your stock shocks and you don’t need a camber ki,unless you want just for piece of mind. Here are 4 links from people that have already installed them on here, myself, mynmisoli, 97_nw, and x2100
https://www.hondacivicforum.com/m_123028/tm.htm
https://www.hondacivicforum.com/m_69.../tm.htm#107781
https://www.hondacivicforum.com/m_150637/tm.htm
https://www.hondacivicforum.com/m_153260/tm.htm
it all really comes down to spring rates and what you are looking for in a ride. s-techs are usually what a lot of people get who are either looking for a nice look to their ride with a softer spring rate. Also, you can use s-techs with stock shocks, so if you dont want to spend a lot of money, then you can go this route.
Else, if you are wanting the stiffer ride, then go with H&R's or eibach springs. with either of those you will most likely need to replace your stock shocks.
i've heard a few people going with neuspeed springs, but those usually aren't the typical springs people like to buy.
here's a list of spring rates...i found these awhile ago...guessing most are still accurate. these apply to the 6th gen civics.
For 96-00 Civics (EJ6-8 and EM1 chassis codes)
96-00 EX - 165F/80R (P/P)
99-00 Si (EM1) - 201F/99.8R (P/P)
97, 00-01 ITR - 250F/250R (L/P)
GS-R - 200F/95R (P/P)
CTR - 240/240 (L/P)
H&R OE - 280F/190R (P/P)
Eibach ProKit - 290F/190R (P/P
H&R Sport - 330F/280R (P/P)
Eibach Sportline - 310F/275R (P/P)
Gold-line GL 2.5" drop - 320/190 (P/P)
Gold-line GPS 1.25" drop - 275/160 (P/P)
Koni RSK Suspension kit - 154-205/270 (P/L)
Neuspeed SofSports - 260F/150R (P/P)
Neuspeed Sport - 280F/180R (P/P)
Neuspeed Race - 485F/395R
Skunk Coilovers -old - 400F/300R (L/L) for civic, 500F/400R for integra
Skunk2 Coilovers - new - 500F/400r (L/L)
Spoon Full Coilovers - 300/240
Progress Coilovers - 350F/250R (P/P)
Progress Lowering Springs - 320F/200R (P/P)
Ground Control Coilover - 380F/280R (P/P) (this is the standard kit and the springs are mildly progressive).
Tein RA/RE/RS - 783F/559R (L/L)
Tein HT - 1119F/448R (L/L)
Tein HG - 365F/129-196R (L/P)
Tein SS - 448F/224R
Tein Flex - 504F/280R
Tein S. Tech - 235F/140R
Tokico Illumina Kit - 250/123 (P/P)
APEX'i WS - 447f/178r
Suspension Techniques - needed
SSR Cup - 392/280
SSR S1 - 448/448
JIC FLT-A2s - USDM - 504F/336R (L/L)
Sparco - needed
CTR - 240/240 (L/P)
Tein SS - 448F/224R
SSR Cup - 392/280
SSR S1 - 448/448
Sparco - needed
Ramyswar
Feb 4, 2012 05:09 PM
SinisterCivic1
Mar 31, 2010 11:42 AM
tuong
Apr 27, 2008 02:35 PM
tuong
Apr 16, 2008 11:28 PM
stechs are great, but if your after a more "stiff" and sporty ride, then get springs w/ a higher spring rate.
