Struts?
Are these worth it and do you think I would have rub issues with 17'sif it was dropped that much and can these be adjusted so there is no drop?
http://www.autopartswarehouse.com/pe...amp;partid=283
ORIGINAL: Overurhead360
there are a lot of people on the forum with that setup, search around and check the product reviews.
probably won't rub but it all depends on your wheel offset, tire size, amount of camber, etc.
I like it, it was great so I could get the shocks and springs together. However, if you're just buying springs, know that the tokico setup is an even drop once done (drops more in front, but it was higher stock or somethign so they end up even at the end). However, It will look like the front is higher than the rear. I don't know why, when you measure it they're even, but in pictures it looks like the front is a LITTLE higher. So, if you're worried about that , then go with s-techs so you know you won't have that issure, and they'll be a little lower.
Danny Boy
Jan 7, 2005 12:12 PM
Danny Boy
Jan 7, 2005 07:47 AM
