Struts question
Old Apr 1, 2008 | 05:59 PM
97Dre's Avatar
Default Struts question
Hey guys, I change my suspension last summer, droped it with Tein S techs and all 4 new struts from monroe. Up her ein Eastern Canada, CRAZY winter, record breaking snowfall amount leading to numerous pot holes and road becoming unbarable. I was drivingon a road i wasnt familiar with, came into an area with TONS of pot holes and i did my best to avoid 80% of them, but beeing 4 in my car with snowboards and stuff, no way i could brake in time toabsorb the bump ahead ididnt i know was about to hit.I ended up taking all 4 wheels off the ground and upon landing, the left rear strutjust gave in, couldnt support the weight(the wheel was two inches inside the rear fender. only the one strut gave in, can i change just that one strut? or do both rear struts have to be changed at the same time?
I know its the strut that busted in the inside cuz it has settled back to its previous position upon time as the spring forced it back to it. my guess is the seal(or some sealing compnent inside the strut) broke under pressure and the fluid on the bottom part of the strut is now all over in the insides.seems like the only thing that could explain it as nothing is broken or loose.
Old Apr 1, 2008 | 06:08 PM
jpnolan's Avatar
Default RE: Struts question
if the other one is fine you dont need to replace both
Old Apr 1, 2008 | 06:18 PM
gokudo_sama's Avatar
When your talking about struts your talking about the shocks or what? If not, can you explain what the difference is? I don't mean to thread jack either. Sorry. Just trying to get this figured out.Thanks
Old Apr 1, 2008 | 06:21 PM
jpnolan's Avatar
on hondas its a strut shock assembly meaning they are one piece
jpnolan's Avatar
sorry that was unclear they are together in one assembly the strut is the assembly that has the shock built into it and the spring sits on it
asechrist
Apr 2, 2010 12:17 PM
pitbull
Jun 1, 2007 08:28 AM
CiViC_NaTioN
Feb 26, 2007 12:59 AM
ic892003
26
Nov 16, 2006 11:47 PM
89civiclx
Feb 8, 2005 10:12 PM
