Suspension help?
i am slo trying to do the same for my 96 honda civic 4 dr. my rear suspension is pretty bad now, and its stock. my car had 166,00 miles on it. do you guys have any suggestions for this car? im also lookin to lowering my ride, im not so sure i thats a good idea tho. u guys can help?
Adjustable shocks are great because you can adjust the stiffness of them, and the comfort of your ride. It's great because you can adjust them to your preferences.
I'd rather have high-quality non-adjustable shocks than cheap adjustables. My MX6 GT had electronically adjustable shocks from the factory. I rarely changed their setting since the "normal" setting was just fine for me. When it came time to replace them, I bought the non-adjustable KYBs and they are perfect. I guess if you track your car every other weekend, having adjustable shocks might be helpful, but I read an article by Lou Gugliotti of LG Motorsports that springs and shocks should be adjusted together, if at all. If you can adjust only one, you can actually end up with handling that is worse than what it was before the adjustment.
well the main reason I recommended adjustable ones is so that you can set them to how you want them to feel. If you buy regular shocks and they're too soft for you or too stiff, you're screwed and stuck with them
Ideally, shocks should be matched to the springs so you can set adjustables to whatever firmness you like but they could easily be mismatched for certain types of driving. This is why Lou G. doesn't like adjustable coilovers - too easy to mess up the ideal combination.
pimp95civ
Oct 6, 2004 01:14 PM
