Suspension question
Old Oct 24, 2005 | 05:58 PM
mxs's Avatar
mxs
Default RE: Suspension question
ok, I know next to nothing about suspension, but I know that's not stock and it does look adjustable. Looks like it can go up some more. You'll need some special wrenches to adjust them, like this:
Old Oct 24, 2005 | 09:24 PM
sacicons's Avatar
you need either those wrenchs posted, or its *possible* with a hammer and screwdriver, but its hell on the perches, and not easy on you.
position the wrenches as shown, and twist in opposite directions, breaking them away from each other, then twist the top one up, counting full turns, so you can get all four wheels up the same amount. then turn the lower perch up into the top one, and jam them back together with the wrenches, opposite of how you got them apart.
[IMG]local://upfiles/436/FF8AB646B11B4C579F9938B8E0EAA79E.jpg[/IMG]
Old Oct 25, 2005 | 06:25 AM
Talon585's Avatar
Where do you buy those special wrenchs?
Old Oct 25, 2005 | 08:07 AM
sacicons's Avatar
an import shop might have an extra set lying around, or maybe Ebay. technically, they are called spanner wrenches, but people might also call them perch wrenches or something like that.
Old Oct 31, 2005 | 10:22 PM
ALX's Avatar
ALX
So obviously you have coilovers which will make the ride really bumpy to begin with. Even if you turn those perches up as high as they go the ride quality is gonna be the same. First off cause they're coilovers which are stiffer springs but, also it looks as though they were installed with stock shocks/struts. At some point you might want to change them out as well so you can improve ride quality if that's a concern.
Old Nov 1, 2005 | 09:32 AM
Dogmeat's Avatar
Someone should mention that adjusting the height on those coil overs will cause alignment issues.....which will cause tire wear.
Old Nov 3, 2005 | 09:42 AM
eg9's Avatar
eg9
HMMMM........i think that you could just replace the springs with some stock ones or maybe if you can get an adjustable strut. you could raise the strut (increasing the distance from bumper to ground) then just throw your springs back on. Im not sure but ill do some research on that. Hopefully the guy didnt cut the springs.
Old Nov 3, 2005 | 12:48 PM
Talon585's Avatar
I still have to raise it up for the winter. I cant be dragging snow everytime i have to drive the car, i was just hoping that the bumpy ride will go away with it raised. Also i am getting a 4 wheel alignment when the car is raised back up.
Old Nov 19, 2005 | 09:31 PM
2000Ex's Avatar
Might be interested how much are you giving them away for?
Old Nov 20, 2005 | 12:39 AM
supapoopa's Avatar
I wouldn't expect much of a improvement in ride and any height with stock shocks on a set of stiff springed coilovers. If they aren't completely gone already from driving around lowered you might notice a slight improvement by raising it to stock hieght since the shock will atleast be working in the range it was designed to work in. Best thing to do would be to try to find a stock set of springs/shocks from a 96-00 civic aleast to be safe during the winter drives.
