suspension removal ?
I have a 2000 honda civic ex and i am trying to lower it using a coilover kit.....i can get the whole stock assemble out of the casr but the strut mounting plate at the top that bolts onto the strut tower how do i get the center bolt loose....i try to turn the nut with a wrench and the strut spinns in the middle...i have the spring compressors on i just ca't break the center nut loose....any one ever encountered this or know what to do......do i need an impact or is there a way to get it to stop spinning....anyone know of any sites that carry the mount plate itself that would also be very helpful thank you very much in advance
i tried the whole allen wrench thing in the top but it didn't work just stripped it....will the vicegrips damage the plastic that goes around the shock itsef or can i ckamp them right on it.....any cheap sites that have the whole kit for my car its a 2000 honda civic ex
are you going to reuse the shock? if so, be very careful with the visegrips, if you scar the rod, it is really bad for them. if you have replacment shocks, just clamp it on the thin metal part, not the rubber boot, and wrench away.
i planned on reusing them for my coilovers so i can drop it down...do you know of any sites that have cheap shocks and the mount that the center bolt is on cause i am looking for that too....thanks a lot for your help sacicons you have been very helpful
spevie
Nov 5, 2004 09:31 AM
