Tires
Old Jun 26, 2007 | 04:11 PM
GReddy_Civic's Avatar
Snail'n Admin
Default Tires
I'm looking at tires for the rims im ordering. What do the tread wear numbers mean. Like what would a number such as 420 mean vs one of 360 or 300. By the way, i am pretty sure im gettin enkei rs5 in silver and then powdercoating them later to possibly bronze with a chrome lip cuz i want my car white or black
Old Jun 26, 2007 | 04:37 PM
civicexracer's Avatar
Default RE: Tires
higher the number, longer the tire life, normally atleast.different companiescan rate differentlybut generally itsabout the same.
example of the ratings:
Falken Azenis RT-615's have a treadwear rating of 200. theira maxperformance tire which means its soft rubber and will wear pretty fast.
Falken Ziex 512's have a treadwear rating of 420. just a high-performance all season so the rubber isnt too soft and will last longer.
Old Jun 26, 2007 | 07:58 PM
conceptualpolymer's Avatar
Default RE: Tires
You can compare ratings of the same manufacturer, but all bets are off if comparing one manufacturer's ratings to a different manufacture's rating. For example, Dunlop's 280 may be the same as Goodyear's 240.
As a general rule, the higher the number, the longer the treadlife, but the worse the handling.
Also, be careful when having aluminum powder-coated. Some alloys, like 7000-series will be severely weakened by the high temperatures required for powder coating. Call the wheel manufacturer, if possible, and ask how high a temp their wheels can be subjected to. Then ask your epoxy powder coating place high high they need to heat the wheels.
soafed
Nov 25, 2008 01:17 PM
remy
Aug 15, 2008 08:13 AM
natecivic92
Jun 4, 2007 07:00 PM
kikaSI
Nov 13, 2006 11:52 PM
bloohatch
Jul 23, 2005 10:05 PM
