Upgrading from stock to 17's
Old Mar 17, 2007 | 07:37 AM
Nochek's Avatar
Default Upgrading from stock to 17's
I have 14" rims with the honda caps stil on them, and I just got a set of 17's. My car is dropped 1.5", hopefully they fit without rubbing so I wont have to change the heigth, but I was wondering if it was necessarry for my to get a different brake system. Do I need to go with a big brake conversion, or will my stock brakes still give me the stopping power I need on the bigger wheels?
* Im driving a 2000 civic EX with stock struts and a cheap *** bomz coilover system btw
Old Mar 17, 2007 | 10:58 AM
SITNLOW97's Avatar
Default RE: Upgrading from stock to 17's
You will be fine with a 1.5 drop without rubbing and no u dont need a big brake kit unless u just have alot of money and want to spend it on that..
Old Mar 17, 2007 | 01:47 PM
dblclutchin's Avatar
No you don't need a big break kit unless you plan on tracking but otherwise it's a huge waste of money. You won't have any problems with rubbing but if you have a camber kit it is best you check the camber when you get bigger wheels to see if you have to adjust it again.
Old Mar 17, 2007 | 03:50 PM
Powermidget's Avatar
You dont have to get bigger bakes but it looks alot better when your brakes fill up that space...there are a few compaines that make oversized rotors for stock calipers...might want to look into them next time you replace rotors
Old Mar 17, 2007 | 06:27 PM
ej6buddy's Avatar
powerslot makes big brake rotors and accessories for cheap for 6th generation civics with abs brakes, i was looking into them, but, i don't have abs
Old Mar 17, 2007 | 07:50 PM
mill$civic's Avatar
I have 17" wheels with about a 1.8 drop. I dont have any rubbing issues, only if you drive really fast over big speed bumps or somthing. And you dont need to upgrade or brakes or anything. Just slap them on and go.
halfpower
May 15, 2009 10:33 AM
deadphishy
Feb 17, 2007 09:25 AM
hockeyc574
Nov 17, 2005 12:46 AM
maniac
Jan 22, 2005 08:54 PM
razzle
Nov 28, 2004 10:11 PM
