is a wheel alignment necessary after doing this?
Old Jun 13, 2007 | 01:35 PM
ic892003's Avatar
Default is a wheel alignment necessary after doing this?
is a wheel alignment necessary after getting new rims and tires, its the proper tire eize with 16 in ch rims , 205-45-16, the streering is ok, but the wheel does shake a tad and is a little off, should i jus get the alignment?
Old Jun 13, 2007 | 02:05 PM
Fiirkan's Avatar
Default RE: is a wheel alignment necessary after doing this?
no it is probably balancing that is doing the shake
Old Jun 13, 2007 | 02:17 PM
civicexracer's Avatar
wheels need balancing.
Old Jun 13, 2007 | 02:24 PM
ic892003's Avatar
correct me if im wrong but wasnt it already balanced when the guy put the rim into the tire for me?,
Old Jun 13, 2007 | 02:30 PM
mxs's Avatar
mxs
they could have done a bad balancing job...
Old Jun 13, 2007 | 02:34 PM
ic892003's Avatar
how much should it cost to rebalance my tires, why is an alignment not necessary?? just curious shouldnt u get one after new rims and tires??
Old Jun 13, 2007 | 02:38 PM
if u payed for just to have the tires put on, then theres a good chance the guy obviously didnt balance. the tire mounting machine and wheel balance machine are compeletly different. balancing shouldnt cost more than like $40, dosnt take long and is easy to do. putting new wheels on dosnt affect toe or camber in any way. if it did, ppl would be getting alignments like theres no tomorrow...
Old Jun 13, 2007 | 02:52 PM
jbum's Avatar
alignment is needed to realign the suspension geometry. new wheels shouldn't change the geometry. if the wheels are not straight, that is a whole different issue but it's not fixed with an alignment. you'll need one if you change a ball joint, shocks, springs, etc...
Old Jun 13, 2007 | 03:06 PM
ic892003's Avatar
thanks for clearing that up, well the guy did balance my tires i saw him put it on the machine, i guess he did a crappy job
josephemorgan91
Sep 30, 2014 09:00 PM
bronxbomerss2
Mar 20, 2012 12:36 PM
civicexracer
May 8, 2011 04:07 PM
sik92civic
Feb 27, 2011 01:09 PM
D16Punk
Jul 4, 2006 09:15 AM
