wheels? sorry guys
Old Nov 17, 2008 | 06:53 AM
silverbullet01's Avatar
Default wheels? sorry guys
i have a 98 civic coupe and is dropped about 2 inches. im looking to get 16 inch wheels and im not sure what offset and everything it should be? any help would be great thanks,
Old Nov 17, 2008 | 07:27 AM
xsteinbachx's Avatar
Please try reading the stickys before posting it helps from repeated questions, but thanks for apologising . Sexy coupe Btw
https://www.hondacivicforum.com/foru...ad.php?t=58727
Q. I just lowered my car... will my tires rub?
A. Well, we need some information here. Generally speaking, it won't matter how much you lowered your car or what size your wheels are. What we need to know is: are you using the right tire size? Also (and this is the big one), what is your wheel's offset? For the most part, anything smaller than 18" should not have rubbing problems (on 7th gen and earlier civics) when you lower your car, assuming you have the correct offset.
Offsets are kind of tricky, to be completely honest; too low of an offset and the tire will rub on the outside of the fenders, too high of an offset and the front tires will rub the inside of the fender around tight turns (my old EG had the rub marks to prove it). Generally (for EGs and EKs anyway), for a 7" wide wheel, +40 may rub in some cases, +42 should have no rubbing problems, and +45 might rub the inside of the wheel well around turns.
phan10m
May 4, 2007 08:19 AM
315 Customs
12
Oct 16, 2006 11:55 AM
my_hidden_romance
Dec 9, 2005 12:58 PM
BlueEX
Aug 22, 2005 11:39 AM
