Will these springs work with these struts??
Old Jun 29, 2009 | 06:32 PM
mountain_man's Avatar
Question Will these springs work with these struts??
I have a 2001 Honda Civic LX 4dr. I currently have all stock coil springs and shocks. They are worn out and I would like to replace them with aftermarket parts. I am looking to lower the car a little bit, but still have a smooth ride. I also need to keep it cheap. I was thinking of using Eibach Pro-Kit Springs and Tokico Struts (HP Series). Will these work together? How will the ride be? Thanks in advance for your input.
Part # 4051.140
http://eibach.com/cgi-bin/htmlos.exe...30713800003271
Tokico Struts HP Series
Part # Front HB3204, HB3205 Back HU3741
http://www.hitachi-hap-la.com/Tokico...08_CATALOG.pdf
Old Jun 29, 2009 | 06:52 PM
As long as those are both for your car it will fit.
Old Jun 29, 2009 | 07:04 PM
Sigracer10's Avatar
thats a great entry level combo. Eibach makes great springs. I have the sportline springs and love them.
and the Tokico blues (HP series) complement the pro-kit springs very nicely.
I've seen a few people on this forum start with this setup and they all were happy. and if i remember correctly, the main reason some of them don't run them anymore is because they upgraded to coilovers.
Old Jun 30, 2009 | 06:25 AM
Thanks for your input. I have another question. Do I need a camber kit?? I am only going to drop the car about an inch. I plan on keeping 14 inch rims on the car. Thanks
Old Jun 30, 2009 | 06:43 AM
No, a camber kit isn't required. Negative camber isn't too bad for the tires until you get past about -4* of camber; then it starts killing tires (I lowered my old civic 2.5" up front and 3.5" out back and had -3* all around).
Just make sure you go to an alignment shop and have the toe set back to factory specifications after you lower the car (give it about a week for the springs to settle before going).
Kirk
Dec 7, 2009 04:59 PM
smokingemcee
Jul 3, 2005 02:29 PM
eastside93civic
Apr 13, 2005 09:47 PM
eastside93civic
Apr 12, 2005 10:34 PM
lilol89crx
Jul 29, 2004 06:56 PM
