Wobble Issue
Old Nov 10, 2008 | 10:29 AM
khanselman's Avatar
Angry Wobble Issue
On my way home Friday from work I hit a piece of metal shaped like a V that was in the middle of the road and ultimately unavoidable by the time I saw it.. in doing so I slashed a good 2" hole in my front passenger inside tire wall. Tire went flat instantly and I pulled over, put my spare on, and drove home (approx. 2 miles).
With absolutely no money in my bank account my father helped me out and found 2 185/70R14 tires for $10 each.. however they are mismatched brands - but they had more tread on them then my current front tires. I had them installed this morning for a temporary fix until I can get some new tires on the front. However, driving into work this morning anything above 15mph I feel a wobble in the steering wheel and the car vibrates. Could this be because of the mismatched brand / tread wear? Or could there be something worse?
Old Nov 10, 2008 | 10:53 AM
inthezoneac's Avatar
maybe you bent a rim. When my front rim was bent my steering wheel wobbled a lot past 30mph, but you could always feel it.
Also check to see if anything got messed up in the suspension front and rear.
Old Nov 10, 2008 | 11:41 AM
jprommel's Avatar
Angry Admin
oh and dont forget the obvious possibility... lol check the lugs see if theyre tight i know i forgot to tighten it with the wrench after putting my wheel back on and the wheel started wobbling =] never forget to check the easy ****, chances are you arent as stupid as i am but never hurts to check.
Old Nov 10, 2008 | 11:55 AM
khanselman's Avatar
Yeah, I talked to my father today and told him that the car shakes now and he said that they might not have balanced them properly and that I should bring it back to the shop and have them re-do it.
I agree with all that has been said. Also consider that the wheels are simply way out of balance.
mudhenFUF
Jan 16, 2023 08:43 PM
DXpert
Apr 26, 2008 06:21 AM
Gonzo
Mar 8, 2008 10:24 AM
10isAce
13
Feb 10, 2007 11:56 AM
cvcman
Feb 21, 2005 10:03 PM
