97 civic d block tranny ?'s
Old Oct 21, 2008 | 10:55 AM
lost8848's Avatar
Default 97 civic d block tranny ?'s
i've got a 97 civic with
ACT Stage 3 clutch
ACT 8.8 lbs flywheel
ACT pressure plate
OEM throwout bearing
Phantom Grip LSD
SRP 9:1 Compression Pistons .020 bore over (75.5mm)
Eagle Rods
New stock Honda Crankshaft D16Y8
ACL Bearings
ARP Headstuds
All belt and gaskets were replaced when engine was rebuilt
OEM Honda Headgasket
Head was port matched to intake and exhaust manifold
Head was also resurfaced
Yonaka Radiator
greddy t3/t4 50 trim tubo kit running 10lbs of boost.
I want to put a new tranny in this thing that will handle some serious power so i can up my boost from the 10lbs. I have no idea where to look or if i could just get a rebuild kit with hardend gears and better synchros or what. Any help would be great. Soon the car will have an aem tuner a boost controler and prob atleast 450cc injectors maybe bigger. thanks
Lambo Civic
Mar 23, 2012 05:42 AM
tombakers
May 4, 2008 05:23 AM
Lost
May 2, 2007 10:52 AM
jo7man4
Jan 27, 2007 01:13 PM
BillyB98
Aug 17, 2006 05:06 PM
