adjusting clutch engagement pedal good/bad?
Old Jul 22, 2009 | 07:42 AM
fst100's Avatar
Question adjusting clutch engagement pedal good/bad?
i just bought a 92 civic vx that has ~168K miles and the trans and clutch are both original with no signs of slippage nor grinding gears. i've been spending some time searching regarding this particular topic and i heard a bit of mixed views. from one side i hear that honda clutches tend to catch at just near the top rest area of the pedal. i also heard that if adjusting the timing of the clutch via the rod underneath the foot panel where it goes out through the firewall and into the master cylinder that you risk shortening the life of the clutch(i dont know how u could as it really depends on how long u press the clutch and the gas anyways). i drove a few other cars that the timing of the clutch can be adjusted and they're both hydraulic. one being a domestic 2.2ecotec and the other and a 240sx chuki.
those who are still confused heres an example:
click here
and here too
i looked in the civic and it also has the same rod and screw thats in my 240sx. can i adjust it so the timing of the clutch pedal be more towards the middle and not near the top resting point? thanks in advance and for your expertise and support
Old Jul 22, 2009 | 08:35 AM
Old Jul 22, 2009 | 08:37 AM
fst100's Avatar
thanks ronj, i actually was reading that just now. if i turn the rod torwards the firewall will that allow the clutch to engage towards the floor or towards the top?
Old Jul 22, 2009 | 08:40 AM
I think that moving the locknut toward the firewall would lift the pedal.
Old Jul 22, 2009 | 08:42 AM
fst100's Avatar
what do u mean "lift the pedal"?
Old Jul 22, 2009 | 08:49 AM
The clutch will disengage at a higher pedal height.
patbrost
Apr 10, 2012 09:05 AM
madjoker14
Apr 12, 2009 06:19 AM
addiction2bass
Apr 13, 2008 05:19 PM
reverendwallis
Mar 12, 2008 10:05 AM
pregohatch
Apr 14, 2006 08:15 AM
