advise on transmission swap...plz
Old Feb 9, 2008 | 10:39 AM
NPcivic95's Avatar
Default advise on transmission swap...plz
whats up guys
I got a 95 civic DX and a 94 civic EX. The DX is a 1.5 non vetec and the EX is a 1.6 vetec. The DX has Manual Tranny and the EX is an automatic. Is it possible to swap both of the trannies?? I want the manual tranny from the DX in the EX and the auto in the DX. will the DX tranny handle the 1.6 vetec?? and would it even fit?? thanks.. any info would be great...
Old Feb 11, 2008 | 11:37 AM
Default RE: advise on transmission swap...plz
the transmissions will bolt right up, but the gearing might not be the best (I think the dx is geared kinda long)
Old Feb 11, 2008 | 11:51 AM
Fiirkan's Avatar
yeah the tranny will fit, you will also need to swap over the pedal assembly. the master cylinder, transmission bracket(part on the frame). you will need to put in he clutch relay on the EX as well. And to wire up the lights to work with the manual tranny
The ONLY thing you will need separately is the Manual P28 ECU for the EX as well.
Old Feb 11, 2008 | 02:06 PM
StifflersMom's Avatar
Cat Fuсker
or you can convert an auto P28 into a manual P28...but you'll still need a P06 for auto which are cheap and plentyful...
henry959
Mar 6, 2013 09:43 AM
q8-ctr
Jan 27, 2010 04:22 PM
Alex1518
Sep 16, 2007 03:14 PM
that_guy5
Feb 9, 2007 08:09 AM
pkennedy
Nov 28, 2006 11:55 AM
