automatic shifter wiring harness
Old May 22, 2007 | 05:21 PM
Imari007's Avatar
Default automatic shifter wiring harness
i have a 98 honda civic lx, which i recently swap to a 5-speed....now 6 months later, the car wont start at all and makes no sounds when I turn the key. I am positive its not a battery, starter or alternator problem...so i was wondering (since i kept it in the car) if the automatic shifter wiring harness (which is located under the shifter) affects the starting mechanism if the harness happens to go out.
to make a long story short...when i swap the car...i set the auto shifter wiring harness (adjuster) to neutral so i would be able to take the key out when the car was turned off...so i dont know if the auto sensor/signal thingy on the wiring harness has gone bad or over-circuited
i would greatly appreciate it if someone could help me out!!!!
Rsporty
Feb 13, 2010 04:22 AM
chrismeister21
Aug 24, 2008 03:30 PM
mpenner
Jun 24, 2008 05:56 PM
Imari007
May 23, 2007 02:37 AM
cokljlc
Sep 27, 2005 01:29 AM
