today i noticed this
Old May 22, 2007 | 05:53 PM
ic892003's Avatar
Default today i noticed this
today i noticed that it takes a little more effort to shift gears, wut can this be? is it a sign of my tranny going bad?? bad syncros, something i should really worry about, maybe change the mtf fluid
Old May 22, 2007 | 06:09 PM
AgentofDarkness's Avatar
Default RE: today i noticed this
If you haven't changed the MTF in a while, change it. After you drain the fluid, you can check the fluid for bronze metal shavings which are a sign of worn out synchros. There are detents in the shifty fork, if there is a problem with these detents, it can make it harder for you to move the shift lever. Are any gears in particular giving you a problem?
Old May 22, 2007 | 06:17 PM
ic892003's Avatar
well when i go to neutral to first it does require a little effort, form 1st to second it takes effort, from 2nd to third it takes less, effort, from third to fourth even less effort and then to fifth no effort, i know ppl say it doesnt matter if u change mtf fluid cause manuals dont really need it,but think it would be a better
Old May 22, 2007 | 06:30 PM
ic892003's Avatar
also, when i shift into reverse nice and slowly it goes in fine, but if i shift too fast, then it grindsssss
Old May 22, 2007 | 07:15 PM
Live_4it's Avatar
Did you bang on your shifter linkage at all? It it's warped it can make it tougher to shift into gears. You could try putting a new bushing into your shifter linkage. Theres also a bushing under your shifter boot that might of gotten torn or something just speculating. I would change the transmission fluid though, i'm going to do it soon to my manual soon.
Old May 22, 2007 | 07:29 PM
Roadkillboy0's Avatar
should i be able to pull my car outa 2nd and 3rd gear without having to push in the clutch? expecially in 3rd if im going about 25 mph i can very easily pull the shifter down into neutral
98civex
Dec 27, 2006 11:30 PM
amg6975
Oct 24, 2005 09:28 PM
xe1002
Oct 21, 2005 11:32 AM
Nail I3unny
May 14, 2005 02:39 PM
