Automatic trans problem
Old May 5, 2012 | 09:08 PM
rosevillain's Avatar
Default Automatic trans problem
'94 Civic EX, automatic, 1.6 liter, 270,000 miles on car, JDM engine 30,000 ago
Car will shift into any forward gear or reverse, and move under its own power. Will drag with the brake on, or the e-brake set.
After one minute or so, the trans is gone. Back in to park, shut off car, re-start car, moves again for like 30 seconds.
Found that the fluid was low. Re-filled, did not drain and fill, but it is no better. Fluid is redish.
Daughter-in-laws car, son works crazy hours, I'm pretty handy mechanically.
Thanks in advance for any ideas.
Old Aug 24, 2012 | 03:34 PM
Gali's Avatar
hi, I have about the same problem. did you get it repaired?
94civichatchback
Dec 20, 2007 01:42 PM
yetti8
Oct 1, 2007 10:26 AM
bonzitre
Jan 21, 2007 08:51 PM
trishieldfan
Nov 3, 2006 09:27 AM
Lordnismo
Sep 26, 2006 03:07 AM
