Axle
Old Dec 15, 2005 | 09:03 AM
AgentofDarkness's Avatar
Default Axle
I'm planning on changing the axle on my car this weeked, anything i should know? The service manual says to drain the tranny fluid, but last time the mechanic did it and he didn't drain the tranny fluid. Anyone know anything about this? Are there any snap rings or little things i should look for that i might miss?
Old Dec 15, 2005 | 06:57 PM
finalimpact's Avatar
Default RE: Axle
i jack my car up high enough on the side im pulling the axle, no need to drain the fluid then. its really a straight foward procedure. remove wheel, axle nut, lower ball joint, lower strut fork. and all slids out.
all2common
Jul 19, 2005 07:40 PM
drosslg
Apr 16, 2005 11:44 PM
cvcman
Feb 21, 2005 10:03 PM
jtshop
Nov 22, 2004 10:18 AM
