Clutch disengagement problem.
Old Sep 16, 2010 | 07:47 PM
Coop's Avatar
Question Clutch disengagement problem.
I have a 90 hatch with a D16Z6 T3/4 turbo and a 5 speed. I'm looking for some suggestion on where to go from here.
The clutch doesn't disengage. I have replaced the clutch, pressure plate, throwout bearing fork and rod, cable, and even have a different trans in there now. I did find a cracked weld on the clutch/brake pedal assembly so I welded it again then made a brace to reinforce the spot.
The only mod on the trans is a stage 2 competition clutch kit (flywheel, clutch, and plate) all new.
Old Sep 18, 2010 | 07:27 AM
Coop's Avatar
Well I just swapped in a new clutch bracket. That wasn't it either.
Old Sep 23, 2010 | 01:30 PM
Candyman206's Avatar
Something wrong with the cable?
Old Sep 24, 2010 | 06:44 AM
Coop's Avatar
It's actually a new cable. I even checked it's length to the old one, and after testing it I removed all the rubber from it and replaced it with steel.
Old Sep 26, 2010 | 08:36 AM
jwsimons's Avatar
i had this problem once, when i installed new clutch it would not go into gear... i dont remember exactly what i did but i forced it to start and poped the clutch.. it slammed into gear and never had another problem..
is this a new problem after a clutch install???
Old Sep 27, 2010 | 04:52 AM
Coop's Avatar
No the clutch is a new one but I had used the other for 10 months. The problem started with the bolt that holds the throwout fork to the shaft broke and popped a hole in the tranny case. I drove it for a week after I fixed that. I left work went to a buddys house, went to leave and it wouldn't start. I pushed the clutch switch by hand and it started, it wouldn't go into gear so I crammed it and the car started moving. So some where I lost my adjustment. I couldn't just readjust in the driveway either because it was already all the way out.
cvcrcr99
13
Jul 13, 2011 06:44 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
