clutch issues
Old Feb 22, 2008 | 12:06 PM
javon's Avatar
Default clutch issues
ok now it seems like for me to get my car started now i have to pump the clutch.sometimes it stars right up others i have to keep pumping it.is there some type of clutch switch, and if threre is where can i get it from.
Old Feb 22, 2008 | 04:18 PM
civtec00's Avatar
Default RE: clutch issues
is it a hydraulic clutch? it sounds like you either need fluid, or you need to bleed the clutch.
Old Feb 22, 2008 | 04:28 PM
ORIGINAL: javon
...is there some type of clutch switch...
Old Feb 22, 2008 | 04:34 PM
ya theirs a switch on your clutch the upper one which acts like a starter kill if the clutch isnt pressed all the way down. you can simply jump it with a paperclip or wire after unpluging the switchs wire plug... to see if its just that pin switch, but if it doesnt work then it could be a bad relay.
mine did stick afew times.... i figure its just a sticking switch with it being so cold out. that the switch is just sticking in. but when i instaled my remote starter/alarm i just bypassed that pin switch with a paperclip, now i just HAVE TO BE SURE its in neutral!
you could try look at the upper pin switch and put some oil on your fingers with the clutch pressed all the way down try to reach up at the same time and put some oil on the pin itself that way it lubes it up a bit. that should keep the pin from sticking just work the clutch a few times to try and force the oil into the small gaps and hopefully it wont stick anymore.....
WD-40 spray would also work BUT it would also spray everything else and leave your car with a wd40 smell! best to just rub some oil with your fingers on it.
Old Feb 22, 2008 | 04:54 PM
javon's Avatar
yep i think it might be the relay . what type of relay do i need and is it hard to install.oh yeah when i hold the clutch in and turn the key sometime it will start like two or three seconds after that like it was late getting the signal so some times im just out keep cranking it till it starts it starts when it wants to
VXHatchHero
Jun 13, 2010 09:42 AM
90jdmcivic
Jun 5, 2008 07:58 AM
EdV
Mar 7, 2008 07:52 AM
Mundo
Jan 8, 2007 11:20 AM
gillespiecd
Mar 21, 2005 03:48 PM
