View Poll Results: A poll
over 75% life left
0%
from 50-75% life left
100.00%
from 25-50% life left
0%
under 25% life left
0%
Voters: 1. You may not vote on this poll
CLUTCH LIFE.. how much is left? larger pictures
Old Sep 22, 2007 | 06:02 PM
Default CLUTCH LIFE.. how much is left? larger pictures
well just pulled my motor/tranny apart and at least its not close to the rivets... but wondering how much life ya think it still has?
since i havent seen another clutch im hoping you guys can help me out... and REMEMBER pictures are VERY LARGE so i wont put them up but only put down links to them...
how much life ya think is left outta this clutch?
http://i40.photobucket.com/albums/e2...t/2ae752ea.jpg
http://i40.photobucket.com/albums/e2...t/da67ac24.jpg
http://i40.photobucket.com/albums/e2...t/1b37d328.jpg
http://i40.photobucket.com/albums/e2...t/87b2c317.jpg
http://i40.photobucket.com/albums/e2...t/6ba9ad45.jpg
Old Sep 23, 2007 | 06:16 AM
foress_89's Avatar
Default RE: CLUTCH LIFE.. how much is left? larger pictures
I have no idea.. but it looks better than mine haha
Old Sep 23, 2007 | 06:20 AM
Fiirkan's Avatar
I didn't even look at the pictures and i can tell ya, if you don't know and you have the tranny off... replace it simple as that
Old Sep 23, 2007 | 10:31 AM
well i know it looks ALOT beter than the one on the motor i bought that they guy removed! BIG TIME ... its not down to the rivets... i just dont know how thick they are new....
just look at this one picture
im trying to save alittle here if its not worn that bad! i dont plan on realy racing it hard but i will Faround with it alittle bit... but mostly just easy shifting....
Old Sep 23, 2007 | 03:03 PM
well dang..... guess ill just have to take it to the dealership and ask to see a new clutch....
i never thought it would be such a untouched topic... about clutches...
Old Sep 23, 2007 | 03:06 PM
ef4life's Avatar
it looks pretty decent, but i would still replace it. it could have gotten oil or trans fluid on the surface and it could slip, then you have to spend 5+ hours replacing it when you could have just spent 100 bucks or less on a new one.
its your choice. it does look like it has some decent life left in it tho.
Old Sep 23, 2007 | 04:11 PM
can you get a pic of the pressure plate and flywheel i want to see a pic of the pressure plate flipped over
Old Sep 27, 2007 | 01:03 PM
sorry pictures not great... but i will clean it up with some brake cleaner ....
and the pressure plate looks all good.... no bent feet no scratches... dad just said take some 400grit sandpaper on the presure plate and flywheel just to clean up the surface alittle...
and well i FINALY got the sockets i needed today for the flywheel bolts and clutch BUT i cannt get the freaken clutch alignment tool.... AWWWWWW need to post a need alignment tool thread realy quick..... anyone got one laying around you can overnight me thru USPS? paypal ready....
Old Sep 27, 2007 | 03:42 PM
foress_89's Avatar
I'd change that pressure plate, I don't like the look of the face. You'd probably need to have your flywheel resurfaced too!
Buy a kit you'll get an alignement tool. I have one but It's not mine! And I'd keep it too...
Old Sep 27, 2007 | 05:40 PM
knoklu's Avatar
yea i think u should change that pressure plarte you got quite a bit of wear there, you wouldent want the teeth breakin on ya.also i got a question for ya, im changing my clutch this weekend and just want to know the eaisest way to get it out and what to look out for, like when putin the main bearing in and stuff. do you recomend pullin tha whole tranny out, i want to try to get it done in a day but im pretty sure thats not gunna happen lol thanks
