Clutch Slips at 1st gear from a cold start help!
Old Mar 13, 2009 | 09:10 AM
hatchback virgin's Avatar
Unhappy Clutch Slips at 1st gear from a cold start help!
I tried searching the site for this particular problems and some of the symptoms were similar but the circumstances are different. I just got my clutch replaced to stock in July 2008 which means the flywheel was resurfaced twice (once for aftermarket and once for stock clutch). However the flywheels was still in spec according to the mechanic. It was never driven rough nor did I teach my girlfriend how to drive manual tranny on it. I didn't ride the clutch. In fact, the clutch master cylinder was replaced at the same time as the whole clutch. I would assume the clutch fluids was replaced at that time as well as bled.
The clutch engages around the middle of the clutch pedal travel. Clutch grabs fine when pressing the gas in 5th gear from 40mph. My only problem is from a cold start; when the car has been sitting for at least 10 hours. I would let the car warm up until it idles at 750rpm and it slips a little but not as bad as if I just waited 1 minute (1200 rpm). When I shift to first gear after a cold start, it would slip two times and then finally grab in the friction zone (clutch pedal halfway out). I would drive to the first stop sign 1/10th of a mile and when I take off in first gear again, it would slip again but less intensity. I would drive another 1/10th of a mile to the 2nd stop sign and it slipped again a couple of times before grabbing. However, the duration of the slipping is less. By the time on get to the 3rd stop sign another 2/10ths of a mile, it would engage fine regardless how slowly I release the clutch or if I apply more gas. So after driving 0.4 - 0.5 miles, the clutch would engage normal. I don't know if this slipppage is normal. The only thing that was not replaced was the clutch lines and clutch slave cylinder. I don't see any noticeable leaks. I forgot to mention, the rear main seal was replaced also because it was leaking causing some oil to get on the previous aftermarket clutch. Any help would be appreciated!
Sapper Mike
Jun 1, 2011 02:31 PM
Tomo!
Apr 28, 2006 02:02 PM
clic
Jan 4, 2006 01:03 PM
clic
clic
Jan 3, 2006 04:19 PM
