DIY Short shifter install
Old Jun 12, 2006 | 09:09 PM
Street Sniper's Avatar
Default DIY Short shifter install
Ok, this is not a comprehensive pictorial, but we get plenty of questions about it so I took a few pics while I was under there. Also, I have only ever done my 5th gen so I am not 100% sure about other generations, so if anyone else has any input, feel free to chime in.
Take your old **** off. Believe it or not it's just lefty loosy-righty tighty. (Yes, Forty, I know my car is a wreck. Zip it.)
This a no brainer, but I always feel like I have to reiterate putting it up on stands. Don't get under there with just the jack holding it up. I tried it both ways and it's just as easy to jack up one side as it is to do the front, so take your pick.
Before we get under the car, most people will tell you that you have to drop a section of the exhaust to do this, and while it will make the shifter removal and install easier, it's not gonna save you any time, and if your exhaust bolts give you any trouble at all, it'll be way more trouble than it's worth. I have done it both ways and I much prefer making things hard on myself, umm... I mean, I don't like disassembling things I don't have to. On that same note, you don't have to disconnect the linkage from the car, but unlike the exhaust, this will make it easier.
Ok, this is the meat and potatoes of the whole evolution. You can do the whole thing from this pic, unless you are changing the bushings, then you need to get to the other end of this thing (linkage). It's those two 12mm, two 10's and the 12mm bolt connecting the shifter to the linkage. The two 10's are one sided deals, I'll show you a pic in a sec.
Here is one of those stupid bolts. Easy when you have the linkage out. A minor pain if you don't.
I didn't bother to take a pic of the other end of the linkage, but just follow it toward the front and it's one 12mm bolt with a stationary nut.
Here's the old cheapo with the grommet/boot thing and plate. Put some sort of lube on that boot before you try to get it over the fulcrum ball thing or you will tear it. Same goes for putting it on the new one. (Note all the highly technical terms. Good thing I have pics, huh?)
Ooh, the good stuff.
The new one with the old boot.
...and if I may borrow a quote from Hayne's, "Installation is the reverse of removal."
All done.
Just a little side note. That cheapo ebay one was totally worth the 15 bucks I paid for it, but only because I couldn't afford a quality one at the time. If you only have a few bucks and zero ability to save (like me), the generic one will tide you over until you can get a nice one. I was surprised at how nice the Skunk2 unit is and I am usually not a label *****.
Old Jun 13, 2006 | 08:34 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: DIY Short shifter install
You better do the poly bushings....they're freagin unbeliavable..and if your stockers look like what yuu had at the shifter...ummm...there a lot of play in there just because of the bushings.
Old Jun 13, 2006 | 09:03 AM
ORIGINAL: Street Sniper
tee he he
Nice write up sniper, this will definitely come in handy
Old Jun 13, 2006 | 10:24 AM
riceburner700's Avatar
showed me what i needed
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
heathershonda
12
May 10, 2007 07:18 AM
ELECTRON BLUE 2000
Apr 18, 2007 11:00 AM
05CivicLX
Jun 4, 2005 12:46 PM
cnote
Apr 18, 2005 12:37 PM
