gear oil?
Old Mar 22, 2005 | 03:01 PM
sugerbear008's Avatar
Default gear oil?
has anyone put 10w40 in there manual transmission?
Old Mar 22, 2005 | 04:04 PM
copyguy6188's Avatar
Default RE: gear oil?
not me, but for a while had a grinding problem when i shifted into 4th gear. did some research and found a product call bg syncroshift. i put that in my man-trans and drove over 20k and still not grinding in any gear. I highly recommened that product (B G Syncroshift). It will run you about 35-40 bucks for the 3 QT's you need.
Old Mar 22, 2005 | 05:03 PM
StifflersMom's Avatar
Cat Fuсker
I have 5w-30 castrol syntec in there....but only because I have a crapload of that. Manual recommends 10w-40 so I guess that's what you should use
Old Mar 23, 2005 | 02:34 PM
Kappa22's Avatar
I use 10-40 all the time.
Old Mar 23, 2005 | 05:10 PM
i wasn't specific 10w40 motor oil? i know that is the specified weight from the factory but will i mess up something using motor oil instead of gear oil?
Old Mar 23, 2005 | 07:34 PM
Kappa22's Avatar
Actually, Honda manual trannies have always used 10w-40 MOTOR oil, NOT gear oil (at least as far as 6th gen; not sure about 7th).
Old Mar 24, 2005 | 03:43 AM
that's what i thought when i did the swap on the 94 but i recently changed it on the 96 and it smelled like gear oil i just replaced it with motor oil. and kept it rolling.
Old Apr 4, 2005 | 02:40 PM
FG078's Avatar
Honda & other Japanese car manufacturer uses 10W-30 or 10W-40 engine oil as a transmission fluid for all their FWD car as far as I know.
honda_dud
Jul 10, 2009 06:48 PM
chasemclemore
May 18, 2009 04:21 PM
oilltd
Jun 10, 2008 04:06 PM
MasterJT
May 18, 2008 05:37 PM
