Loud transmission Plz help
Old Oct 27, 2007 | 01:38 PM
blazz's Avatar
Default Loud transmission Plz help
hello all,
i get a loud grinding noise in all gears, but gos away when i push in the clutchor when im just cruising
but comes back when i accelerate,
yesterday i puled the trany to switch out the throwout barring, but after it was out i foundi had the wrong part[:@], i checked the old throwout at that time and it seemed like i need a new one, it spun easy, but sounded like it had no grease in it,
i was told it was the throwout, but if so why will it be ok when im cruisin,
Only when accelerating or down shifting you can here it
Old Oct 27, 2007 | 05:05 PM
SovXietday's Avatar
Default RE: Loud transmission Plz help
Definitely sounds like the throwout bearing.
You've probably got two problems. Throwout bearing is probably shot, and I wouldn't doubt that the ISB (input shaft bearing) is shot as well. Replace the throwout bearing and see if your problem goes away, if it doesn't it's the ISB which is much more of a pain in the ***.
Old Oct 27, 2007 | 05:18 PM
StifflersMom's Avatar
Cat Fuсker
eh...ISB is like a 5-6 hour job if you're got a good toolbox....took me about 8 hours the first time I did it, but I was druuuunk.
Old Oct 29, 2007 | 05:06 PM
blazz's Avatar
im going to post a video of the sound when driveing, but i need to get a new SD card reader first,
ISB? i hope not
Is that 5-6hr job with the tranny out!!?
do i need any special tools for the job?
also i was going to ask if anyone has ever seen a speedometer bug out B4,
but i found out it was blowing the Sp sensor/alternator fuse, do to a short in the wiring harness, under the intake
silvercivic12
Oct 3, 2011 06:05 PM
islandtuner
May 4, 2009 08:54 AM
cohen_fetters
Apr 6, 2008 10:43 AM
that_guy5
Feb 9, 2007 08:09 AM
TrAvMaNFTW
Feb 19, 2006 12:19 PM
