Lucas Transmission Fix Q.
Old Dec 27, 2005 | 03:28 PM
2000Ex's Avatar
Default Lucas Transmission Fix Q.
In my manny tranny I know how to check the fluid. Using the bolt and sticking your finger in there but to add the fix stuff do i add it down there or is there a resoiver. It is a 5 spd btw.
Old Dec 27, 2005 | 03:52 PM
dj_ipirate's Avatar
Default RE: Lucas Transmission Fix Q.
i just like saying manny tranny to myself... manny tranny. ... ... he he ... manny tranny.
anyways. you can just put it in the resoiver
manny tranny.
Old Dec 27, 2005 | 07:03 PM
2000Ex's Avatar
I do not see a tranny fluid resiovor.
Old Dec 27, 2005 | 07:10 PM
sacicons's Avatar
you add it to that same hole. theres no res.
Old Dec 27, 2005 | 07:23 PM
2000Ex's Avatar
So to add 12-24 ounces should I park on a decline or remove some of the old tranny fluid.
Old Dec 30, 2005 | 03:47 PM
xjbmx's Avatar
I would drain all the fluid, and add the recommended amount of lucas and then fill it up the rest of the way with the normal 10W-30. It only holds about 1.8 quarts. The drain plug is further down on the lowest part of the side of the tranny. You stick a 3/8 ratchet in the square hole and take the bolt out and all the oil drains. It'll only take an extra 15 minutes to do it the right way.
Old Dec 30, 2005 | 08:39 PM
2000Ex's Avatar
Yea I was thinking about just doing the whole thing since there isn't jsut a res. to top off. Does Honda make their own tranny fluid or is there like a certain brand I should go for?
Old Dec 31, 2005 | 01:34 PM
xjbmx's Avatar
Honda does make their own and i think its around $5 a quart. If your close to a dealership i would so go ahead and use their stuff. However you can use regular 10w-30 or 10w-40 just make sure it is some decent stuff (go sythetic). It is also important to get a non-detergent type oil because it can create excess bubbles and reduce lubrication.
maroon
Jan 2, 2023 02:21 PM
Shandles
May 29, 2016 04:14 PM
theRDRman
Nov 3, 2010 08:59 PM
Blue Canon
Jun 21, 2008 10:31 PM
maroon
May 25, 2008 07:22 PM
