Man-u-el tranny oil--How in - what weight
Old Nov 19, 2006 | 06:31 AM
tlkolrod's Avatar
Default Man-u-el tranny oil--How in - what weight
Good morning, I have a 97EX civic manual trans. How do you get oil in and what weight weight is best for PA area temps? I know how to get it out just did not find fill hole yet?? Thanks Toby
Old Nov 19, 2006 | 11:50 AM
riceburner700's Avatar
Default RE: Man-u-el tranny oil--How in - what weight
just either get regular motor oil or some honda manuel trannsmission fluid OR gm synchromesh for manuel trannys. if you are getting regular oil go with 5w/30 for colder weather or 10w/30 for hotter weather is what honda recommends
Old Nov 19, 2006 | 04:19 PM
civicexracer's Avatar
https://www.hondacivicforum.com/m_293737/tm.htm
Old Nov 19, 2006 | 05:12 PM
HARI.'s Avatar
i use 10w-40 motor oil for my tranny fluid, and i fill it up through the VSS hole. much easier IMO. you don't need a hose. all you need is a long funnel.
oilltd
Jun 10, 2008 04:06 PM
DickG.
May 23, 2008 02:44 PM
mill$civic
Sep 27, 2005 01:06 PM
the_reptilian
Sep 29, 2004 10:53 AM
