at to mt??
hi, my aunt just gave me a 95 civic ex coupe cause the motor was shot. it had a at in it, so my friend and i want to swap in a b18c5 and sell it, so what do you have to do to get themt in itinstead of the at?
Please use this in the future: https://www.hondacivicforum.com/search.asp(no offense or anything... it's just this kind of thing has been covered time and time again)
Aaaaaaaanyway...
-(obviously) Manual transmission
- Shift linkage
- manual ECU (you can keep the auto ecu, but it'll throw a CEL... )
- a new clutchkit is recommended (clutch disc, pressure plate, throwout bearing)
- shifter/shift ****
- master cylinder/slave cylinder (if they didn't come with transmission)
- Manual pedal set
- If you don't have a tach, I'd recommend you get a guage cluster with a tach (ex/Si)
EDIT: Oh, and this should help: https://www.hondacivicforum.com/m_295187/tm.htm
Aaaaaaaanyway...
- Shift linkage
- Manual pedal set
