my civic idle at ...
Old Jan 10, 2007 | 10:54 AM
stefo's Avatar
Default my civic idle at ...
around 500 400 or so... and at times its just below 1000 rpm ... the engine has onle 65 600 miles on it and its stick shift... even when everything is turned off lights, cd player, a/c, heat, jsut the car running and it idles at liek 5 or 40 or just below 1000.... whatcould be the problem and would my warrenty cover it?
Old Jan 10, 2007 | 10:55 AM
cderalow's Avatar
Default RE: my civic idle at ...
year of car?
Old Jan 10, 2007 | 06:31 PM
stefo's Avatar
2000 honda civic ex 4 dr 5 speed.. stock
Old Jan 10, 2007 | 07:48 PM
Misha's Avatar
Normal idle is around 700, exact number depending on trim/year/country. What exactly you think your problem is? Idle too low? Idle too high? Erratic idle? Oscillating idle? Try to be more specific...
Old Jan 10, 2007 | 08:05 PM
stefo's Avatar
well if my idle is at like 300 400 i think its too low... dont you... and at times its right below 1000.... it switchs around ... wtf is wrong with and how can it be fixed...?? it shouldnt have any problems its a 2000 with 65 600 miles on it...
Old Jan 10, 2007 | 08:09 PM
Misha's Avatar
How can you measure 300-400? Your tachometer most probably goes down to 500, then there are no marks until zero.
Anyway, I would start with EACV if your idle botheres you. Remove and clean it, and then we'll see
Old Jan 10, 2007 | 09:22 PM
ic892003's Avatar
i had a similar problem, their was a clog in the iacv valve, i would get that cleaned first
honvic
Sep 2, 2011 09:49 PM
JBaris
Nov 22, 2010 03:56 PM
jlh911
15
Jul 9, 2005 09:08 AM
jlh911
Jun 27, 2005 08:23 PM
Ed
Feb 27, 2005 07:29 PM
