New Tranny Soon~!
Old Dec 18, 2009 | 06:14 PM
JayVee's Avatar
Arrow New Tranny Soon~!
Okay well after reading the whole Transmission FAQ i learned quite a bit, but my tranny is slowly going out and i can really tell now. It used to just grind in 2nd gear, but now it's grinding in 3rd gear also. So i've came up with a solution after reading the Tranny FAQ.
Only problem i've got is this:
Originally Posted by danomatic93
any hydraulic D-series tranny (the zc is an exception, but you can make it work) from a 92-00 civic. Make sure it's a D-series tranny (SOHC!, not DOHC). If you have a z6, I would reccomend getting another Z6 tranny (92-95 EX/Si) or "upgrade" to a D16Y8 tranny (96-00 civic EX/Si).
Tranny's will have a code by the trans fluid fill plug that reads A000 or B000. A000 has small bearing case and B000 has large bearing case. So, B000 is better.
Here's where you can find the code:
A000's are from HX, DX, CX, VX models [gear ratios better for high end]
B000's are from EX, Si (SOHC only) models [gears ratio better for low end]
The Y8 tranny is "better" because it's composed of steel instead of aluminum like the Z6.
Also, the Y8 has one gear that has a slightly higher gear ratio than the Z6.
Z6 M/T gear ratios: Y8 M/T gear ratios:
1ST: 3.250 1ST: 3.250
2ND: 1.900 2ND: 1.909
3RD: 1.250 3RD: 1.250
4TH: 0.909 4TH: 0.909
5TH: 0.702 5TH: 0.702
Reverse: 3.153 Reverse: 3.153
Final Drive: 4.250 Final Drive: 4.250
I recommend getting a B000 and a Y8 if you can get one.
I'm deffinatley going for the EX Y8 tranny. But if the Y8 tranny is B000, how could you get both? Also, replacing my existing D16Y7 tranny with the Y8 one it should be "plug&play" correct?
Old Dec 18, 2009 | 09:30 PM
yes it just bolts up with no problems or any modifications required, they have the exact same casings(bolt pattern), just the internals are different.
Old Dec 19, 2009 | 04:34 PM
JayVee's Avatar
yeah it's the best of Dseries i take it.
hmm, but the Y8 tranny is B000? like there isn't a Y8 tranny A000 correct?
Old Dec 19, 2009 | 04:56 PM
the y8 is from a ex and the ex code is b000
Old Dec 19, 2009 | 08:19 PM
JayVee's Avatar
hmm, okay. so i'm guessing that guy made a typo. thanks 94chb
Old Dec 26, 2009 | 02:29 PM
Dipsetcivic117's Avatar
how can you tell if the b000 tranny is from eg or ek civic
Old Dec 26, 2009 | 11:32 PM
JayVee's Avatar
hmm, good question.
Old Dec 27, 2009 | 08:53 AM
well trans mounts are different and also the starters are different ,
Old Dec 27, 2009 | 10:08 AM
so i will basically find out when i install the motor/tranny and if the tranny doesnt line up, then its from a ek? but im guessing that my tranny is from a eg because i stole the starter from the new motor to put it in my motor thats in the car now.
Old Dec 27, 2009 | 11:17 AM
yeah if the starter from the new trans fits ur trans then its from a eg, ek trans will line up just like the eg trans they are the same, i was saying the starters are different a eg starter wont fit on a ek trans and vise versa
