problem adding manual transmission fluid
Old Apr 13, 2005 | 10:35 AM
wohnny's Avatar
Default problem adding manual transmission fluid
I followed the Haynes to check and add some oil to my manual transmission, but the hole that was used to check/fill is blocked. Maybe I took the wrong plug off, but I couldn't fit any kind of tube into there, so I filled my oil up through the drain plug until it flowed out of the check/fill hole..basically did it the oppositte way, but I had no other choice, because the check/fill plug was blocked by some metal thing that I could actually turn a little bit...there was basically no hole. Anyone have any idea what I"m talking about? This was my first time doing any kind of significant maintanance on a car and I was pretty stumped.
Old Apr 13, 2005 | 08:16 PM
AOL.COM's Avatar
Default RE: problem adding manual transmission fluid
every honda trans i ever drained/ filled had a3/8 square plug ----top one -fill ---bottom one -drain
Old Apr 14, 2005 | 10:24 AM
wohnny's Avatar
yeah, i took out the bottom one to drain, and I took out the top one to fill it, but when i went to put my flexible tube in, the opening was blocked by stuff. Am I suppoed to thread a really really tiny tube in there or something to fill it?
trustdestruction
Routine Maintenance DIYs
Apr 30, 2010 08:53 PM
enigma34
May 13, 2009 06:41 PM
fastlane9
Jan 2, 2009 09:01 AM
03civex
Feb 26, 2008 04:07 PM
s0ulj3r
Jan 15, 2008 07:34 PM
