Short Shift Adaptor or Short Throw Shifter
Want to shorten the throw, but I came across two different types. A short shift adaptor and the short shift lever. Is one of these better than the other? Can you use both? Is there any advantage to using both?
[IMG]local://upfiles/2869/57EA55A6777041ED8D65B73D40C82A50.jpg[/IMG]
you dont need the adapter for the shifter.. pick either. its best to get a new shifter because ure stock one isnt going to handle too much abuse and will break fairly quik if u are racing. make sure its steel and none of that alluminum ****.
eLantern
Aug 29, 2006 01:08 PM
