Short Shifter Question
Old Aug 31, 2008 | 08:17 PM
jprommel's Avatar
Angry Admin
Default Short Shifter Question
What is the difference between these two short shifters, i see that one has the factory bend but i am unsure of exactly what that means. I'm thinking that it means that the one without the factory bend will be further away from me but im not sure so i would like to get your input. Thanks in advance. =]
One with factory bend. http://www.bmracing.com/s.nl/c.72308...&category=6068
One without factory bend. http://www.bmracing.com/s.nl/c.72308...&category=6068
p.s. should i also purchase new bushings? i keep seeing references to them and how they make the shifting smoother.
Old Sep 1, 2008 | 07:31 PM
i'm kinda confused
the first link goes to some weird shifter called a "ratchet shifter"
the second link goes to a shifter with a bend
but to answer your question, one without the factory bend (straight) will have the shift **** farther away from you
energy suspension shifter bushings are amazing, and inexpensive. do it
Old Sep 1, 2008 | 08:10 PM
jprommel's Avatar
Angry Admin
whoa the links changed. but hey you answered my question so thank you.
Old Sep 1, 2008 | 08:22 PM
oh yeah, i forgot to mention, the one in the second link is actually dual bend, which is different from the factory bend, however it will still bring the shift **** closer to you, just like a single bend (factory-style) shifter. And there are single bend short shifters, as well as dual bend and straight.
Single Bend and Dual Bend:
Straight:
Mr^Man
Transmission and Differential
Oct 19, 2008 04:21 PM
heathershonda
12
May 10, 2007 07:18 AM
ELECTRON BLUE 2000
Apr 18, 2007 11:00 AM
Talon585
Nov 21, 2005 06:59 AM
05CivicLX
Jun 4, 2005 12:46 PM
