si tranny Problems!!!!!
Old Jul 6, 2005 | 12:56 AM
nwhite82's Avatar
Default si tranny Problems!!!!!
i just replaced my clutch and now my tranny doesnt want to go into gear. when the car is off it will go into gear smoothly, but when it is on it doesnt want to go into gear with out forcing it and wont go into reverse at all, it just grinds. I put new fluid in, would too much cause this? how much fluid does a si tranny hold and what type is the best?
Old Jul 6, 2005 | 08:00 AM
Super Mario's Avatar
Default RE: si tranny Problems!!!!!
YOU just replaced the clutch or YOU just GOT it replaced. sounds to me like there is an issue with the actual clutch. take it back to the place that did the work and tell them. if you did it yourself then you'll need to take it apart again and see if every thing is ok in there! Good Luck!
Old Jul 11, 2005 | 06:06 PM
jamend0za's Avatar
it sounds like ur syncros arent lining up correctly... id agree with mario... either reinstall of take it to a pro
Old Jul 11, 2005 | 07:08 PM
LEVIII's Avatar
When you say you put in tranny fluid what exactly did you use?
Old Jul 12, 2005 | 12:18 AM
sacicons's Avatar
ORIGINAL: LEVIII
my thoughts too.[&:] dont know if thats the problem though, but its probably internal.
sway2003
Apr 22, 2008 12:15 PM
Civic Dx 349
Nov 7, 2007 06:35 PM
davster
Sep 28, 2007 10:23 AM
pregohatch
Jul 9, 2006 09:21 AM
darknightmr2
Mar 14, 2006 06:44 PM
