si trans any better than cx?
Old Feb 21, 2006 | 07:24 PM
finalimpact's Avatar
Default RE: si trans any better than cx?
si/ex are your best bet....you can use 92-00 civic transmissions including the del sol, all bolt up the same way just slightly different internally. the d15b if im not mistaken is geared the same as the si and does have the option of lsd. and seeing that your using a b15b8(assuming its stock) swap the head out to the very least a d15b7 as your head is only an 8 vavle head. swapping to a 16 valve head will open your engine up.
Old Feb 22, 2006 | 07:18 AM
jusplayn85's Avatar
ORIGINAL: finalimpact
I'm actually finishing up a d16z6 head swap right now... My clutch is the next step, I hate the feel of the stock clutch. And when I heard about the trans I figured that it might be worth it to do while I'm doing the clutch. But that definitely sounds like the way I'm going to go. Thanks for all the info...
Old Feb 24, 2006 | 08:24 PM
riceburner700's Avatar
ORIGINAL: ef4life
the si has closer gear ratios which allow for faster acceleration and are good for high rpm n/a motors. longer gearing like a cx trans is for better economy and a broader power band like in a turboed car
yeah thats why i am lovennnnnnnnnnnnn my cx with turbo.
Old Feb 24, 2006 | 10:24 PM
ef4life's Avatar
ORIGINAL: riceburner700
ORIGINAL: ef4life
your lucky you have a turbo, maybe this summer for me.
Old Feb 24, 2006 | 11:19 PM
sacicons's Avatar
i believe the only difference between the EX and Si trannies is the fifth gear, so i like the EX one a little better since its got a slightly longer 5th gear, and should give you a little better economy on the highway.
Old Feb 24, 2006 | 11:21 PM
Nail I3unny's Avatar
ORIGINAL: dj_ipirate
are you sure? i herd at hond's launch of the new si, that this is the first time lsd has came with a civic
only in america.
Old Feb 25, 2006 | 12:45 AM
Pete's Avatar
I wouldnt get a new trans, just an LSD Check out qualiffe
Old Feb 25, 2006 | 12:05 PM
Kedawei's Avatar
lol Quaife
Old Feb 28, 2006 | 09:02 PM
97civicturbo's Avatar
So for turbo the cx tranny IS better?
Kenneth Ames
Nov 7, 2006 09:50 PM
rit14623
Mar 2, 2006 02:26 PM
psychocivic
Jan 29, 2006 01:14 AM
Remmy
Nov 13, 2005 08:13 PM
z6 FoRiLLa
Sep 26, 2005 05:50 PM
