Tranny Dissasembling
I just removed the tranny from my civic. I'm changing the clutch, and I tought I might at the same time make sure everything is fine inside the transmission. I just want to make sure the gears are not rusted and/or eaten.
It's out of a 91 SI. I'm not sure of the model but I believe it's an L3?
I know there is a DIY on this subject, I looked at it. I got the 12MM bolts and the crack, but not the snap ring. I'm used to snap rings with holes... This one doesn't have any. I opened it with long-nose pliers, but still I couldn't pry the tranny open....
I would appreciate tips and/or links!!
Thanks.
Thanks.
you guys are too slow.. I got it xD
Only one of the gears looks eaten a little bit, I don't know how you call it, but it's the one that is most to the right. All alone at the bottom... I don't know if it should be changed? It's not badly injured, but it is a little..
sway2003
Apr 22, 2008 12:15 PM
davster
Sep 28, 2007 10:23 AM
pregohatch
Jul 9, 2006 09:21 AM
darknightmr2
Mar 14, 2006 06:44 PM
