transaxel broke?
Old Jan 8, 2008 | 11:10 AM
matticuscontra's Avatar
Default transaxel broke?
Ithink the something happened to my transmission/clutch/cvjoint?!the car runs, does not shift into gear. just a grinding noise. AndI dont even have to push clutch in to shift into gear. Nothing happens when i shift into gear. The grinding stays steady whenI try shifting into gear, except whenI push the clutch in and put in reverse it stops grinding.BUT whenI barely barely let the clutch a little bit the grinding starts again.And goes no where. Before it stopped driving and the clutch just totally disengaged it self or whatever happened to it, WhenI would drive and shift gears occasionally it would seem it swing back and the engine would hit the firewall. andI wasnt power shifting or driving at high rpms.I just thought thatI needed new motor mounts.wtf's my problem and how much would it cost to fix it?[/align]
Old Jan 8, 2008 | 12:44 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: transaxel broke?
input shaft bearings and the clutch
Old Jan 10, 2008 | 04:39 AM
do you have a general idea of how much that might cost, parts, labor ballpark?
Impreza WRX
Jan 27, 2006 03:05 PM
Jas
Oct 6, 2005 01:48 PM
blippo
Sep 15, 2005 08:37 PM
se7ensectoolate
May 2, 2005 12:17 AM
uplink
Apr 9, 2005 04:56 PM
