Transmission grinding 3rd and 5th
Old Jun 24, 2006 | 12:09 PM
ITGPerformance's Avatar
Default Transmission grinding 3rd and 5th
I am new here, looking into purchasing a 94 civic ex. I have been test driving one and have found that underload at about 5 grand and up, if I try and shift from 2nd to 3rd it will grind. It is even worse from 4th to 5th. The owner of the car says that he has no problems with it if the clutch is all the way depressed. However, I made sure the clutch was al the way in before shifting and it still grinds. I am thinking its the synchros going out. The owner had the car checked out and they said there was nothing wrong with the synchros ( I doubt they drove the car around and checked to see if it did grind at high rpm) Is there anything else that would cause this grinding into 3rd and 5th but no other gears?
Thanks,
Jeff
Ramyswar
Nov 9, 2011 08:20 AM
EJ8_Man
May 18, 2009 06:16 PM
didder
May 15, 2008 09:06 PM
Seamus
May 28, 2007 08:44 PM
sirjames
May 10, 2007 06:34 PM
