underdrive pulley installation questions
Old Apr 17, 2006 | 02:17 PM
riceburner700's Avatar
Default RE: underdrive pulley installation questions
unorthadox racing makes lightweight pulleys that are the same size as the orinaly pulleys so they dont reduce alternator outputs or power steering or ac components... same goes with aem. they are ENGINERED for more power with still being safe on an engine....
Old Apr 17, 2006 | 02:35 PM
StifflersMom's Avatar
Cat Fuсker
I was not talkign about accessory pulleys. What I said was that crank pulleys hurt your engine.
Old Apr 17, 2006 | 04:15 PM
finalimpact's Avatar
true they hurt your engine......but only if your engine is equiped with a harmonic type balancer found on the 1.6+ engines.....the 1.5 come with a non balanced pulley and can use a underdrive lightweight pulley without problems.
Old Apr 17, 2006 | 04:28 PM
Cat Fuсker
ehh isn't the 03 lx a d17? what about those?
Old Apr 17, 2006 | 04:57 PM
probably will have one for the d17 for limited vibration help
Old Jun 17, 2006 | 06:19 PM
FlipHKD720's Avatar
Alright thread from the dead with this one.....but i'm looking into an underdrive pulley kit and found this thread.
So you guys are saying this would actaully hurt my electrical power output? I have subs and neons and all that fancy stuff, so i definately don't want to lose electrical power.
Old Jun 17, 2006 | 11:54 PM
AgentofDarkness's Avatar
That kit has an alternator pulley, so the alternator will be putting out less power. The whole point of underdrive pulleys is to turn the accessories (alternator) slowers and turn the transmission faster. This puts more power to the wheels. In your case, the alternator will be putting out less power. Underdrive pulleys are a bad idea on a street car, but an especially bad idea on a car with as much stuff as you. You might even want to look into an alternator that makes more power, not something that reduces the power of your alternator.
Old Jun 17, 2006 | 11:57 PM
Cat Fuсker
Rebuild your alt for a high power application and than use that kit...
Old Jun 18, 2006 | 08:51 AM
Chimera02EX's Avatar
^ Unorthodox Racing pulleys only underdrive the accessories by 10-13%, they are the same size as OEM, their gains come from being lighter. Also no matter what anyone says the Honda SOHC motors do not have any kind of harmonic balancer, so no the pulleys will not hurt your engine any more than any other performance mod you make.
Old Jun 18, 2006 | 10:57 AM
FlipHKD720's Avatar
So you trade accessorry output for 5 horses at the most? Is the electrical outpot noticable? I.E. lights dimming when subs hit, etc.
