Water pump and clutch suggestions
Old Dec 8, 2007 | 02:50 PM
Revn7's Avatar
Default Water pump and clutch suggestions
I have a 00 Ex and it has 194,000 milesand I need to replace the water pump and everything involving that and I need to replace my clutch. Would it be better to pull the motor and change both that way, or leave it in and do them? What components and brand would should I go with for both? I am at least going with a stage 1 clutch, not sure on what flywheel. I do auto-x. And a pulley system. Any info would be great.
Old Dec 9, 2007 | 05:58 AM
gsumano's Avatar
Default RE: Water pump and clutch suggestions
I think it would be easier to do one at a time without taking out the engine. For example, replace the timing belt and waterpump first and then move onto replacing the clutch.
For the timing belt, I recommend getting an OEM from the dealership and for the clutch, I recommend an Action clutch.
Old Dec 9, 2007 | 07:44 AM
well for the water pump and such, water pump/ tension pulleybearing/belt.. I SUGEST OEM......
not sure for your clutch tho.... i have a oem replacement clutch by EXEDY.
Old Dec 9, 2007 | 10:17 AM
rcalimquim's Avatar
yea water pump and all go with the dealership parts, parts from pepboys etc... usually dont fit the car right. now the clutch you can get a performance one cheaper than the dealership and its better and stronger, i'd go with a carbon clutch from ACT, also get the lighten flywheel from them. you'll feel alot better shifting, dont go with a puck clutch they tend to be more rough DD.
flcb7
Nov 3, 2010 05:21 PM
SpeedRacer_87
Jul 29, 2007 09:41 PM
POLYTHING
Sep 17, 2006 11:26 PM
LIhybrid
Oct 13, 2005 03:04 PM
smokingemcee
Aug 9, 2005 10:36 PM
