Audio/Video & Electronics DIYs For all you sound/video junkies
Headlight Warning Chime (92-95 Civic)
Old 04-21-2008, 09:38 AM
danomatic93's Avatar
June 2010 ROTM
Default Headlight Warning Chime (92-95 Civic)
Hopefully this gets moved to the DIY section...
For 92-95, there was an optional headlight warning chime. That being said, all you have to do it get a chime (maybe from radio shack) and hook it up.
Remove the driver's side kick panel (3 screws) and also the metal safety brace (2 10mm bolts) that is behind the kick panel.
On the fuse box, towards the top, is a series of 5 emtpy male prongs. You simply hook the chime to the 4th and 5th prongs.
With the key OUT of the ignition, turn you headlights on. If it doesn't chime switch the wires, the polarity might be wrong.
Old 04-21-2008, 08:46 PM
bigmikew1's Avatar
Default RE: DIY EG "Headlights On" Warning Chime
kool. and how much did it cost?
Old 04-21-2008, 11:25 PM
June 2010 ROTM
$4 or so. Small buzzers are cheap!
Old 04-22-2008, 02:28 AM
if this is for what im thinking it is, mine came with one of these as standard. it beeps when your lights are on and the drivers door is open without the ignition on? is that what this is for?
Old 04-22-2008, 03:32 AM
June 2010 ROTM
Yeah, some cars had them standard, but in the US it was a dealer option that nearly no one took.
Old 04-22-2008, 05:34 AM
lcn584's Avatar
in relation to ryanej2's reply, with this accessory, it only beeps or chirps or whatever when the headlights are on with the key out? i was hoping to have something like that which works when the key is inserted to the ignition and with the lights left on too. i would think for this function, i need another chime or perhaps plug it in a different location?
Old 04-22-2008, 11:54 AM
bigmikew1's Avatar
$4!! im gonna buy that today lol.
Old 12-02-2008, 05:15 PM
i'm gonna do this sometime this week
bump for dan, this needs to be in the DIY section. nice write up.
EDIT: well, maybe not
trent tells me it won't work with a turbo timer, which I will have semi-soon
Old 12-02-2008, 05:44 PM
ltkenbo's Avatar
I find this kind of humorous cause on the 6th gens a lot of people want to remove the buzzer.
TiggerDX
10-08-2012 04:39 PM
celinaroc
03-29-2010 05:21 PM
bdouglas
07-01-2009 10:44 AM
civic_burns_all
07-28-2007 05:27 PM
blue_eyed_boarder
10-20-2006 04:29 PM
Quick Reply: Headlight Warning Chime (92-95 Civic)
