Proper D16Z6 Timing/ Idle Adj Procedures
Old 04-30-2011, 07:28 AM
dbrine's Avatar
Default Proper D16Z6 Timing/ Idle Adj Procedures
I have a 94 Civic EX with a D16Z6. I recently changed the timing belt, etc. What are the proper procedures to timing the engine with the timing light and adjust the idle controls? I aligned the timing marks, etc when I did the change and the car runs great.
I have a timing light already and tachometer with alligator clips for adjustments to the idle controls. Where do I connect the tach at since the coil is in the dizzy?
thanks,
Old 11-08-2011, 09:17 PM
srdaniel's Avatar
I'm not a mechanic, but on my 93 D15B7, I clamped my sears engine analyzer tach lead, based on the manual, onto the #1 cylinder spark plug wire as close to the distributor as possible.
myfirsthonda
07-16-2009 07:40 PM
scottdh20
04-24-2008 04:54 AM
vugoodoll
12-16-2005 02:24 PM
forcefedcivic27
08-24-2005 06:52 PM
vmf
07-29-2005 07:17 PM
Quick Reply: Proper D16Z6 Timing/ Idle Adj Procedures
