mind of its own!!!
mind of its own!!!
okay i have a honda civic dx 1.5
i replaced the
starter
fuel pump
fuel filter
& battery...
but lately it only wants to start when it wants
when the key is turned the check engine light turns on...when it turns off the car will start,otherwise it'll just crank.
my father messed with i believe the fuse box... i have the idea its the alarm system..
anyone has any ideas,anyone??
i replaced the
starter
fuel pump
fuel filter
& battery...
RE: mind of its own!!!
ORIGINAL: cricket
i replaced the
starter
fuel pump
fuel filter
& battery...
i replaced the
starter
fuel pump
fuel filter
& battery...
http://www.honda-tech.com/zerothread/1901557
Alternatively, you can take the car to AutoZone where they will retrieve the code free of charge.
ORIGINAL: RonJ
hey are you sure about that? Because then i will take my car there too
You have a bad main relay. every honda ever made has a bad main relay. when you turn on the ignition, the main relay directs power to various parts of the car. when everything else works, and the car cranks but refuses to start, that part of the relay that is going to the ignition module is not sending out it's signal. If you check to see if the plugs are getting spark, you will find that there is no sprark.
The main relay is a small 2" square module hidden in the dash area. after a few years of use the solder joints go bad.
you can take the unit out, and reheat the connections with a solder iron. it cost nothing, and it will worklike new.
Go to the general tech help forum, and look at "problems solved", the first listing is for this problem, that all hondas share. it gives detailed info, and it is not a hard repair
Good luck
Dave
Good luck
Dave
^ absolutely the main relay, man. Classic case. There will be no OBD code from a bad main relay, it just won't start. The clue is the check engine light doesn't go off after 2 seconds like it should.
